9 years agoError: Failed to initialize the OpenCL/AAL system
When I use the command "aocl reprogram acl0 xx.aocx" to reprogram FPGA, it shows: aocl program: Running program from /root/altera_pro/16.0/hld/board/bdw_fpga_pilot_opencl_bsp_v1.0/linux64/libex...
9 years agoDid you update your OS kernel since then? If you update the kernel, you sometimes have to reinstall the driver. Try "aocl install", then reboot, then try "aocl diagnose acl0"; if it succeeded, retry your reprogram command.
