Altera_ForumHonored Contributor15 years agoError: Erase failed at offset 0, Info: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Info: Resetting and pausing target processor: OK Info: Reading System ID at address 0x00001828: verified Info: Info: : Checks...Show More
Altera_ForumHonored Contributor15 years agoare you sure that the EPCS controller is at address 0x0 in your SOPC system?
Recent DiscussionsFree Licence for Max+PlusIIMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected report
