11 years agoTwo lines of the trace give me a clue but not how to solve it:
--- Quote Start --- Warning (10230): Verilog HDL assignment warning at altera_merlin_width_adapter.sv(958): truncated value with size 24 to match size of target (8) --- Quote End --- and: --- Quote Start --- Error (10198): Verilog HDL error at altera_merlin_width_adapter.sv(433): part-select direction is opposite from prefix index direction --- Quote End --- Each of these suggest things may not be connected up as intended. How are you instantiating your qsys module? It looks like "off_chip_mem" is your top level Qsys entity - right? So, you're just throwing your generated Qsys output at Quartus - no higher level vhdl module...? Cheers, Alex
