gbarc2's avatar
gbarc2
7 years ago
Error compiling hello_world.cl with aoc
I recently installed the Intel OpenCL SDK toolchain for FPGA on a Linux system by following the guide provided here https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/opencl-sdk/aocl_getting_started.pdf.
Since our board is an Intel PAC with Arria 10 GX, I also installed the Custom Platform for the board.
Running
aoc -version
Intel(R) FPGA SDK for OpenCL(TM), 64-Bit Offline Compiler
Version 17.1.1 Build 273
Copyright (C) 2017 Intel Corporation
quartus_map --version
Quartus Prime Analysis & Synthesis
Version 17.1.1 Build 273 12/19/2017 Patches 1.02dcp,1.36,1.38 SJ Pro Edition
Copyright (C) 2017 Intel Corporation. All rights reserved.
therefore aoc and Quartus are installed. I also ran "aocl diagnose" and it correctly passed the diagnostic for the board.
Then compiling the hello_world.cl kernel in emulation mode
aoc -v -march=emulator -board=pac_a10 hello_world.cl
worked without any problem (also at runtime the binary worked).
However, running
aoc -v -board=pac_a10 hello_world.cl
c: Environment checks are completed successfully.
aoc: Cached files in /var/tmp/aocl/ may be used to reduce compilation time
You are now compiling the full flow!!
aoc: Selected target board pac_a10
aoc: Running OpenCL parser....
aoc: OpenCL parser completed successfully.
aoc: Optimizing and doing static analysis of code...
aoc: Linking with IP library ...
Checking if memory usage is larger than 100%
aoc: First stage compilation completed successfully.
Compiling for FPGA. This process may take a long time, please be patient.
Error: Compiler Error, not able to generate hardware
Therefore, I looked at hello_world.log (see attached) and there is no indication of why the compilation failed.
Then, I looked at quartus_sh_compile.log and the only line reported is
ERROR: packager tool failed to run. Check installation. Aborting compilation!
Could you please help us understand where the issue may be?
Many thanks.
  • SMelz's avatar
    SMelz
    since December 2019 (after an ubuntu update)
    we have this error:
    aoc device/hello_world.cl -o bin/hello_world.aocx
    Error (213009): File name "output_files/afu_fit.green_region.pmsf" does not exist or can't be read
    Error: Quartus Prime Convert_programming_file was unsuccessful. 1 error, 0 warnings
    Error (23031): Evaluation of Tcl script a10_partial_reconfig/flow.tcl unsuccessful
    Error: Quartus Prime Shell was unsuccessful. 7 errors, 3326 warnings
    Is there any solution?
    Simon
  • KhaiChein_Y_Intel's avatar
    KhaiChein_Y_Intel
    Hi Simon,
    This thread is closed since May 2019. Could you open a new forum thread?
