Error Code (121014): Net HEX2, HEX1, HEX0 cannot be assigned to more than one value. If someone can help that would be greatly appreciated.
module bcd_seven_seg(SW,HEX0,HEX1,HEX2,LEDG);
input [9:0] SW;
output [6:0] HEX0, HEX1, HEX2;
output [9:0] LEDG;
wire [6:0] hex0,hex1,hex2;
assign HEX0 = ~hex0;
assign HEX1 = ~hex1;
assign HEX2 = ~hex2;
bcd_seven_seg_behavioral u0(SW[3:0],HEX0);
bcd_seven_seg_behavioral u1(SW[7:4],HEX1);
bcd_seven_seg_behavioral u2(SW[9:8],HEX2);
endmodule
module bcd_seven_seg_behavioral(bcd,hex);
input [3:0] bcd;
output reg [6:0] hex;
always @ (bcd) begin
case(bcd)
4'b0000: hex <= 7'b0111111;
4'b0001: hex <= 7'b0000110;
4'b0010: hex <= 7'b1011011;
4'b0011: hex <= 7'b1001111;
4'b0100: hex <= 7'b1100110;
4'b0101: hex <= 7'b1101101;
4'b0110: hex <= 7'b1111101;
4'b0111: hex <= 7'b0000111;
4'b1000: hex <= 7'b1111111;
4'b1001: hex <= 7'b1100111;
4'b1010: hex <= 7'b1110111;
4'b1011: hex <= 7'b1111100;
4'b1100: hex <= 7'b0111001;
4'b1101: hex <= 7'b1011110;
4'b1110: hex <= 7'b1111001;
4'b1111: hex <= 7'b1110001;
endcase
end
endmodule
1 Reply
- ak6dn
On these lines:
the second arg HEXn is an OUTPUT of this function.
And nowhere do you assign a value to 'hexN' before using it.
I think the above lines want to be:
bcd_seven_seg_behavioral u0(SW[3:0],hex0);
bcd_seven_seg_behavioral u1(SW[7:4],hex1);
bcd_seven_seg_behavioral u2(SW[9:8],hex2);
otherwise you are assigning a value to HEXn via the assign statements, and also the bcd_seven_seg_behavioral module output.
Note verilog is a case sensitive language.
