8 years agoerror: Channel support is not enabled
Hi,I compiled project PipeCNN on the github with Intel OpenCL SDK for FPGA 17.1 and get the following error In file included from /home/wangjf/PipeCNN/project/__all_sources.cl:2: PipeCNN/project...
8 years ago --- Quote Start --- Hi,can you tell me the details of your problems? Thanks. --- Quote End --- Finally it worked out using# pragma OPENCL EXTENSION cl_intel_channels : enable In your original post it was# pragma OPEN EXTENSION cl_intel_channels : enable so it didn't work. Anyway thx! After successfully compiling the conv.aocx file with hw setting (which took hours), running it seems taking forever.. I'm wondering how long does it take you to run it on the FPGA device?
