8 years agoerror: Channel support is not enabled
Hi,I compiled project PipeCNN on the github with Intel OpenCL SDK for FPGA 17.1 and get the following error In file included from /home/wangjf/PipeCNN/project/__all_sources.cl:2: PipeCNN/project...
8 years agoI had the same problem as you. Tried your method and still not working. Can you share how you finally worked it out? Thanks!
