8 years agoerror: Channel support is not enabled
Hi,I compiled project PipeCNN on the github with Intel OpenCL SDK for FPGA 17.1 and get the following error In file included from /home/wangjf/PipeCNN/project/__all_sources.cl:2: PipeCNN/project...
8 years ago --- Quote Start --- I see that you have already opened an issue on Github about this; I recommend waiting for a response from the owner of the repository. My guess is that since the channel extension and functions have been renamed from Altera to Intel in Quartis v17.0 and above, while that project uses the old names, you are running into this issue. --- Quote End --- BTW,I am trying to compile it with VERSION 16.1,however,it points out me that I must have a valid license.So,I can do nothing.:D Thanks a lot.
