17 years ago
Error: Can't synthesize current design -- Top partition does not contain any logic
module testmyand;
reg a,b;
wire c;
initial
begin
a=0;
b=0;
# 5 a=1;
# 10 b=1;
end
myand m(a,b,c);
endmodule
module myand(a, b, c);
// Input Port(s)
input a,b;
// Output Port(s)
output c;
assign c=a&b;
// Additional Module Item(s)
endmodule
when i want to test the second module using the first module ,Error: Can't synthesize current design -- Top partition does not contain any logic
I don't know why?
1 Reply
    --- Quote Start ---
    module testmyand;
    reg a,b;
    wire c;
    initial
    begin
    a=0;
    b=0;
    # 5 a=1;
    # 10 b=1;
    end
    myand m(a,b,c);
    endmodule
    // Input Port(s)
    input a,b;
    // Output Port(s)
    output c;
    assign c=a&b;
    endmodule
    I don't know why?
    --- Quote End ---
    First of all you have no input and output ports in your toplevel specified. With no ports in place the Quartus synthesis engine could remove all your logic ( your and-gate). The initial statement and your# value are good for simulation, but could not be used for synthesis.
    Try this :
    module testmyand ( a,b,c);
    input a,b;
    output c;
    myand m(a,b,c);
    endmodule
    // Input Port(s)
    input a,b;
    // Output Port(s)
    output c;
    assign c=a&b;
    endmodule
