14 years agoError: Can't run SignalTap II Logic Analyzer -- SignalTap II File is not compatible
Hi, I am trying to run SignalTap and see the signals but I get following error. Error: Can't run SignalTap II Logic Analyzer -- SignalTap II File is not compatible with the file programmed i...
13 years agoIn my case, it was because it chose the wrong .sof file. I checked the .sof file, chose the correct one, and it works.
Hope that helps. Regards, intan
