14 years agoError: Can't run SignalTap II Logic Analyzer -- SignalTap II File is not compatible
Hi, I am trying to run SignalTap and see the signals but I get following error. Error: Can't run SignalTap II Logic Analyzer -- SignalTap II File is not compatible with the file programmed i...
14 years agoRemoving the db directory didn't help.
I checked the file names, closed and opened Quartus and none didn't help. can someone tell me how I can disable the on-board configuration controller and how I can clear the cache which may help! Thanks
