14 years agoError: Can't run SignalTap II Logic Analyzer -- SignalTap II File is not compatible
Hi, I am trying to run SignalTap and see the signals but I get following error. Error: Can't run SignalTap II Logic Analyzer -- SignalTap II File is not compatible with the file programmed i...
14 years agoOther possible reasons:
- the *.sof file downloaded by Signaltap is not the design you compiled last. Check the filename (and possibly folder) in the Signaltap window. - Your hardware is reloading the design from AS or other configuration memory after being configured. Disabling the on-board configuration controller may be necessary.
