14 years agoError: Can't run SignalTap II Logic Analyzer -- SignalTap II File is not compatible
Hi, I am trying to run SignalTap and see the signals but I get following error. Error: Can't run SignalTap II Logic Analyzer -- SignalTap II File is not compatible with the file programmed i...
14 years ago --- Quote Start --- Hi, I am trying to run SignalTap and see the signals but I get following error. Error: Can't run SignalTap II Logic Analyzer -- SignalTap II File is not compatible with the file programmed in the device. The expected compatibility checksum value is 0x3015B694; the value read from device is 0x85F4DE2 I add a signal to signaltap and save it. Then I go to Quartun II (version 11.0 Build 208). I compile the design and start SignalTap again and program my device. As soon as I click on run analysis, in front of "Instance" and under "Status", it says "Not Compatible with the device" Please let me know if you can think of any solution. One option might be this. Somewhere in one of the threads, it says that .stp file is cached and it must be cleared. Do you how the cache in Quartus and signaltap can be cleared? Thanks --- Quote End --- Hi, I would close the signaltap file and re-open it again. Kind regards GPK
