8 years agoError: Cannot fit kernel(s) on device
Hello everyone, I want to implement some function of open source code with DE1SoC. The project uses opencl kernel to program the FPGA and have a host program to call the kernel. But when I ...
8 years ago --- Quote Start --- Your kernel is too big to fit on the device. The actual compilation log is quartus_sh_compile.log. If you check that file, it will tell you what resource you are running out of. You probably need to modify the settings of the kernel. Since you are using an open-source project, I recommend contacting the author and asking him for help. --- Quote End --- Thank you! It's useful for me!
