8 years agoerror aocl: unable to determine...
hi
i've installed the intel SDK, and even if i run the init_opencl script, when i try aocl <arg>, i get the following error message: aocl: Unable to determine the execution environment of the Intel(R) FPGA Runtime Environment for OpenCL(TM). aocl: Detailed error: Could not find root directory for the SDK: could notfind the 'share' directory i don't understand the cause of this error, <INTELFPGAOCLSDKROOT>\share exist :confused:. can anyone help me ? thanks for your help3 Replies
- KUcar
Hi;
I have same praoblem to. I work on Quartus 18.1 Standart edition and De1-soc board. My environment variables are:
AOCL_BOARD_PACKAGE_ROOT ----->D:\intelFPGA\18.1\hld\board\terasic\de1soc
INTELFPGAOCLSDKROOT ----> D:\intelFPGA\18.1\hld.
I get errors;
aoc: Unable to determine the execution environment of the Intel(R) FPGA SDK for OpenCL(TM).
aoc: Detailed error: Internal error: Path to SOPC Builder directory is not found!.
Could you help me solve the problem. Thank you.
You set environment variables ALTERAOCLSDKROOT, AOCL_BOARD_PACKAGE_ROOT and more other from *** conflicting manuals of XXI Century ?
Please get more info about your versions. - AUlHa
Same problem as KUcar. Please shed some light on the issue. All the environment variables are set correctly.
