JJLiu
3 years agoError (293007): Current module quartus_map ended unexpectedly.
Hi, I had trouble compiling a simple module :
Error (293007): Current module quartus_map ended unexpectedly. Verify that you have sufficient memory available to compile your design. You can vie...
RichardT_altera
3 years agoAs workaround provided (using a machine with more memory/ code changing/ use Quartus Pro), I will now transition this thread to community support. If you have a new question, Please login to https://supporttickets.intel.com, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you.
Richard Tan
