JJLiu
3 years agoError (293007): Current module quartus_map ended unexpectedly.
Hi, I had trouble compiling a simple module :
Error (293007): Current module quartus_map ended unexpectedly. Verify that you have sufficient memory available to compile your design. You can vie...
RichardT_altera
3 years agoUnfortunately, the engineering team only do maintenance for Quartus standard so this issue is most likely not gonna be fixed as there is a workaround available (using a machine with more memory, changing code or use Quartus Pro version). I am sorry that I can't help you much on this,
Let me know if you need further help in regards to this case.
Richard Tan
