Error (293007): Current module quartus_map ended unexpectedly.
Quartus tool does support +: and -: part-selects.
Reference:
Instead, I saw these errors when try to run fitter stage. You may need to check your design.
Error(22412): The design requires at least 16419 elements of type IO_CLUSTER but the device has only 1857.
Error(22412): The design requires at least 16393 elements of type IO_OUTPUT_BUFFER but the device has only 1037.
Error(22412): The design requires at least 16419 elements of type IO_PAD but the device has only 1269.
Error(16297): An error has occurred while trying to initialize the plan stage.
Richard Tan
- JJLiu3 years ago
Thank you for your attention to my question!
I used virtual pins to avoid the errors you pointed out.
But it still doesn't explain why code with "+ : "compiles out of memory, while code with the same functionality compiles quickly with no errors.
Sometimes it is unavoidable to use "+ :" and "- :" for dynamic interception of fixed bit width. That's when I hit a standstill...So should I set up Quartus to support "+ :"?
In fact, I have selected the Verilog version as Verilog-2001:I would be grateful if you could give me your advice!
