JJLiu
3 years agoError (293007): Current module quartus_map ended unexpectedly.
Hi, I had trouble compiling a simple module :
Error (293007): Current module quartus_map ended unexpectedly. Verify that you have sufficient memory available to compile your design. You can vie...
sstrell
3 years agoWhat does the + do here:
outputWhole[addr*16+:16]
And because of your endianness, doesn't "addr*16+" have to always be between 0 and 15 (<16 that is)?
