9 years agoError (272006): The Logical Element multiplier implementation cannot be used together
I have a compiling problem when I added something in Assignment Editor. I've tried to google it but only got unrelated PDFs. What I try to do is to implement the multiplier in logic elements in...
9 years agoThe link to your code is broken, but the error is saying that you can implement the multiplier using logic instead of a DSP block, but you can't use synchronous clear for the multiplier in this implementation. Without seeing the code, it's not clear why, but this may be an architecture limitation of the Cyclone V device.
