Error (23035): Tcl error: can't find package qsys exactly 20.3 while executing "package require-exac
The command that you use to run the tcl file in incorrect. You should use :
qsys-script --script=my_script.tcl
For further information, please refer to the Platform Designer User Guide on section 7.6. Generate a Platform Designer System with qsys-script
Richard Tan
Hi @RichardTanSY_Altera ,
Thanks for your reply. I could run the TCL script successfully using qsys-script.
Actually, I want to build and compile my design using script. I went through the Intel Quartus Prime Pro Edition User Guide: Scripting (UG-20144).
Following are the tasks to be done.
1. Build the project with initial settings.
2. Add RTL source files to the project.
3. Generate qsys files.
4. Add generated qsys files to the project.
5. Add IO placement and standard assignments to the project.
6. Add SDC file to the project.
7. Compile the project to generate SOF.
From UG-20144, I couldn't figure out how to execute steps 3 to the flow. Can you help me out?
Musthafa V
- RichardT_altera5 years ago
The command-line executable used for platform designer is at different folder.
You can write the script such that it direct to the C:\intelFPGA_pro\21.1\qsys\bin, where the qsys-script.exe located, and run the < qsys-script --script=my_script.tcl> to generate the qsys files. For script used for Platform Designer, please refer to the Platform Designer User Guide (UG-20130)
Fyi, most of the command-line executable mentioned in Intel Quartus Prime Pro Edition User Guide: Scripting (UG-20144) is at C:\intelFPGA_pro\21.1\quartus\bin64.
Richard Tan
