Error (209027) Verification failed
Hi
thanks for your reply.
unfortunately it didn't help.
i also try to erase the data and programming it again (same file of course). both, erase and programming was pass successfully and then i try again to do the verification check and its failed again.
only when i unchecked the CRC check option, i pass successfully. it is the only solution i found till now.
also, i run it on CMD. i try different type of verification command (according to user manual).
i use : quartus_pgm -c USB-Blaster -m jtag -o vi;C:\altera\HTU_TOP.jic;EPCS16
its failed(like at the picture i uploaded)
when i try to change the "vi" command, it successes:
V, CV : pass successfully
Hi @G_H
There might be something wrong with the command.
If you are referring to the quartus_pgm command, the options cannot be vi. It has to be following 1 of the command below.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/tclscriptrefmnl.pdf#page=78
Please try the options provided in the User Guide.
Richard Tan
- G_H5 years ago
hi.
thanks for your replay.
i also try the IV command as its written at the user manual - same result.
- RichardT_altera5 years ago
Hi @G_H
Could you try to use the programmer version that matched with the Quartus project?
e.g. use programmer version 20.1 with Quartus version 20.1
Richard Tan
