Error 199013 199014 QuartusPrime Lite 20.1.1
I have recently been given an Intel DE10-Lite board for my digital logic lab course and I keep running into the same error while trying to run the board on my personal computer. Below I have copied the simulation flow progress excerpt. I have tried clean installing the QuartusPrime software and rerunning the basic setup and still run into these error codes. Sometimes these errors occur on the computers in the lab room as well. I am not sure what I can do to remedy this issue.
Board: 10M50DAF484C7G
Error (199013): HDL output file name "C:/Users/sarah/Desktop/EE 2174/EE2174 Lab/Prime/simulation/qsim/output_files/Waveform.vwf.vt" used with --testbench_file option contains a non-existent directory path Error (199014): Vector source file C:/Users/sarah/Desktop/EE 2174/EE2174 Lab/Prime/output_files/Waveform.vwf specified with --testbench_vector_input_file option does not exist Error: Quartus Prime EDA Netlist Writer was unsuccessful. 2 errors, 187 warnings Error: Peak virtual memory: 4639 megabytes Error: Processing ended: Wed Jan 11 21:05:18 2023 Error: Elapsed time: 00:00:01 Error: Total CPU time (on all processors): 00:00:00 Error.
Thank you for your time.
Try getting rid of that space in the path: "EE2174 Lab".
- sstrell
- black_bleu
I've done that now and it works a little better. Right now whenever I load a wave file it places itself in the wrong file place by default, so i guess fix that every time.
Now that I've corrected all my file pathing issues (which is not corrected when creating a new project file or so) I have this error# ** Error: (vlog-7) Failed to open design unit file "Lab0.vo" in read mode. # No such file or directory. (errno = ENOENT) # End time: 14:44:35 on Jan 13,2023, Elapsed time: 0:00:00 # Errors: 1, Warnings: 0 # ** Error: c:/intelfpga_lite/20.1/modelsim_ase/win32aloem/vlog failed. # Executing ONERROR command at macro ./Lab0.do line 3 Error.do any of you know how to correct this issue? For more clarification I am attempting to run all of my projects off of my thumb drive "E".
- ShengN_altera
Or may be you can try recreate a new project and .vwf file. The --vector_source is the path where .vwf file located. The --testbench_file is the path where .vwf.vt file located. Attached a sample project for your reference.
Sheng
- ShengN_altera
Make sure the .vo file is present in the directory ../simulation/qsim. That file is auto-generated after running simulation in Waveform Editor. May refer to the previous zip file attached.
Sheng
- ShengN_altera
In Simulation Waveform Editor, go to Simulation -> Simulation Settings -> Testbench Generation Command. For both Timing and Functional Simulation Settings, make sure the paths of --vector_source (Waveform.vwf) and --testbench_file (Waveform.vwf.vt) are correct.
Or try to create a new .vwf file.
Sheng
- black_bleu
Dear Sheng,
What is the correct file path for --vector_source and the --testbench_file? Would it be where the --vector_source ".vwf" file is saved? Also the 199013 error seems most consistent as even with a brand new .vwf file this error always occurs. For example what is the intended target of \Waveform.vwf.vt for the --testbench_file option? I don't see this file anywhere. - black_bleu
Also even with using a real directory for the \Waveform.vwf.vt file this error occurs.
Unable to open E:/EE2174 Lab/Prime/simulation/qsim/letThereBeLight.vwf.vt Error.
