yy1
5 years agoError (14566): The Fitter cannot place 4 periphery component(s) due to conflicts with existing const
How can fix the errors?
I really can't understand
Error (175001): The Fitter cannot place 1 HSSI_PMA_CDR_PLL, which is within Transceiver Native PHY Intel Arria 10 FPGA IP edp_rx_phy_16b_a...
Deshi_Intel
5 years agoHi,
From the diagram that you drew, likely this is due to resource sharing issue.
- You are using same CDR_refclk source to clock 2 NativePHY IP where by one transceiver bank only contains 6 channel.
- If you are using CMU PLL, then it will eat up extra transceiver channel as well.
- I am guessing once you remove the second NativePHY design then it free up some transceiver channel resource, that's why no more error
I can't analyze the issue further unless you can share with me your design QAR file. I need to cross check your NativePHY IP setting vs your transceiver pin setting.
Anyway, my suspect is due to insufficient transceiver channel resource sharing issue that caused the error
dlim
- yy15 years ago
Hi Dlim,
Thanks for your explain.
And what's the QAR file mean ? How can I get this file?
Jamie
