Error (14566): The Fitter cannot place 4 periphery component(s) due to conflicts with existing const
Based on the fitter error report, likely there is an pin placement issue on either your CDR refclk pin or transceiver Rx channel pin
I can help to review your design if you can share your archived design QAR file here.
dlim
- yy15 years ago
Use tool : Quartus 18.1 prime standard
Family: Arria 10
Device: 10AX115S3F45E2SGE3
below is design (rx_cdr_refclk0 = 100MHz)
pin planner
set_location_assignment PIN_AC8 -to rx_cdr_refclk0
set_location_assignment PIN_AC7 -to "rx_cdr_refclk0(n)"
set_instance_assignment -name IO_STANDARD LVDS -to edp_ref_clk_pset_location_assignment PIN_H5 -to rx_serial_data[0]
set_location_assignment PIN_G7 -to rx_serial_data[1]
set_location_assignment PIN_F5 -to rx_serial_data[2]
set_location_assignment PIN_E7 -to rx_serial_data[3]set_location_assignment PIN_H6 -to "rx_serial_data[0](n)"
set_location_assignment PIN_G8 -to "rx_serial_data[1](n)"
set_location_assignment PIN_F6 -to "rx_serial_data[2](n)"
set_location_assignment PIN_E8 -to "rx_serial_data[3](n)"set_instance_assignment -name IO_STANDARD "HIGH SPEED DIFFERENTIAL I/O" -to rx_serial_data[0]
set_instance_assignment -name IO_STANDARD "HIGH SPEED DIFFERENTIAL I/O" -to rx_serial_data[1]
set_instance_assignment -name IO_STANDARD "HIGH SPEED DIFFERENTIAL I/O" -to rx_serial_data[2]
set_instance_assignment -name IO_STANDARD "HIGH SPEED DIFFERENTIAL I/O" -to rx_serial_data[3]- yy15 years ago
Hi dlim,
If I try to modify design as below, the error message disappear,
but the source ref clk of the frequency of rx_clkout_16b and rx_clkout_20b are different make 16_to_20bit_fifo module error.
Therefore, I want to use the original design.
What's the problem of the original design?
- yy15 years ago
