10 years agoError (12077): Node instance "Mult0" instantiated with unknown parameter "LPM_WIDTHR"
I am using version 13.1 of Quartus II and this error keeps coming up. There is no where in my code that I can find this node instance or parameter. I did a bit of research to see if other people had similar problems and found this link:
https://www.altera.com/support/support-resources/knowledge-base/solutions/fb237236.html It seems similar but every time I try to do something similar it still doesn't work for me.3 Replies
Are you using some IP generated from a newer version Quartus?
They often change IP blocks between versions so they are no backwards compatible. - Altera_Forum
I a using an IP, I never checked what version it was using. That could be the problem.
Thanks - Altera_Forum
I checked today and the IP core works perfectly on Quartus II version 15. I was trying to do it on version 13.1.
So thank you, you were correct about my problem.
