10 years agoError (12077): Node instance "Mult0" instantiated with unknown parameter "LPM_WIDTHR"
I am using version 13.1 of Quartus II and this error keeps coming up. There is no where in my code that I can find this node instance or parameter. I did a bit of research to see if other people had ...
10 years agoAre you using some IP generated from a newer version Quartus?
They often change IP blocks between versions so they are no backwards compatible.
