11 years ago
Error (12014): Net "a", which fans out to "a", cannot be assigned more than one value
I'm designing a relatively simple circuit. Using two 4 to 2 encoders to realize an 8 to 3 encoder. Only been learning VHDL the last month. I don't know what this error means. I've done similar circuits without error so I'm not sure what the difference is.
Error (12015): Net is fed by "ENCODER4X2:M1|a"
Error (12015): Net is fed by "ENCODER4X2:M2|a"
Error (12014): Net "b", which fans out to "b", cannot be assigned more than one value
Error (12015): Net is fed by "ENCODER4X2:M1|b"
Error (12015): Net is fed by "ENCODER4X2:M2|b"
top design:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
Entity ENCODER8X3 IS
PORT (i0, i1, i2, i3, i4, i5, i6, i7 : IN STD_LOGIC;
error 12014 -> a, b, c, d : OUT STD_LOGIC);
END ENCODER8X3;
ARCHITECTURE STRUCT OF ENCODER8X3 IS
signal w1 : std_LOGIC;
COMPONENT ENCODER4X2
PORT (i0, i1, i2, i3 : IN STD_LOGIC;
a, b, c : OUT STD_LOGIC);
END COMPONENT;
BEGIN
w1 <= not (i0 OR i2 OR i4 OR i6);
M1: ENCODER4X2 PORT MAP (i0, i2, i4, i6, a, b, w1);
M2: ENCODER4X2 PORT MAP (i1, i3, i5, i7, a, b, d);
END STRUCT;
slave device:
LIBRARY ieee;
ENTITY ENCODER4X2 IS
&#8203;error 12015 -> a, b, c : OUT STD_LOGIC);
END ENCODER4X2;
ARCHITECTURE STRUCT OF ENCODER4X2 IS
BEGIN
a <= i3 OR i2;
b <= (i1 AND (NOT i2)) OR i3;
c <= i0 OR i1 OR i2 OR i3;
END STRUCT;
It's probably some stupid mistake that I'm overlooking. I hope so. Any help is appreciated.
1 Reply
    The message is clear.
    You can't drive a node from more than one source by direct wiring. You are driving (a) and (b) by two instants as outputs. If one is driving it high and the other low what is the result?
    This is fundamental rule whether the drive is through assignments or instantiations. If you have to, then you need to decide a priority logic onto that node rather than direct wiring. (for io you can also use Z buffer)
