13 years agoI just verified, that Quartus is also complaining about the original Verilog code, which was expectable.
In fact you can change it to regular synthesizable Verilog by exchanging a few lines, corresponding to the VHDL version shown in post# 5 and# 6. In so far it's completely misterious why the author used the starnge construct. Regarding sensitivity lists, in my understanding, they have been introduced to reduce the effort of a simulator that has to interprete the code. Using process(all) in VHDL (or always @* in Verilog) means that the simulator has to compute all expressions for each delta cycle, but also avoids all possible simulation mismatches related to sensitivity lists. You can argue that sensitivity lists are ignored in synthesis anyway, so if you are only simulating synthesizable code, or not simulating it at all, you can use process(all) without changing anything. P.S. The corrected Verilog codealways @(posedge clk or posedge rst )
if (rst) begin
m_wr_pnt<=0;
write_cnt<=0;
new_bw <=0;
read_cnt<=0;
end
else
begin
new_bw <=0;
if (we_m) begin
if (free_bd >0) begin
write_cnt <=write_cnt+1;
m_wr_pnt<=m_wr_pnt+1;
if (!write_cnt) begin //First write indicate source buffer addr (2x16)
bd_mem<=dat_in_m;
end
else begin //Second write indicate SD card block addr (2x16)
bd_mem<=dat_in_m;
new_bw <=write_cnt; //Second 16 bytes writen, complete BD
end
end
end
end
