13 years ago --- Quote Start --- Thus the question is: What is the proper pattern to assign some output signal in the process on clock edge, but only till next clock and only if some (maybe complex) condition is met, and else set it do default value? --- Quote End --- you can use default statement: if reset ... elsif rising_edge(clk) then data <= '0'; if condition1 then data <= '1'; end if; end if; condition1 will be checked at every clock edge and if not true then '0' is assigned on data
