14 years agoI am having the same problem too - Error 10818 (does not hold its value outside the clock edge) and 10822 (couldn't implement registers for assignment on this clock edge) but i cant understand what changes do i need to do.
I am trying to build a Counter that count the time user successfully catches a number 8. If it is, then a logic '1' will be sent out and a signal will record the times of success events and sent out too. I have another question is "can i use rising_edge to detect any change of logic value for any time of signal ? std_logic / unsigned / integer .. etc .... Here is the code --- Quote Start --- library IEEE; use IEEE.std_logic_1164.all; use IEEE.std_logic_arith.all; entity catch is port ( PUSH : in std_logic; COMP : in unsigned(3 downto 0); RST : in std_logic; INC_FREQ : out integer range 1 to 10; SCORE_COUNT : out std_logic ); end catch; architecture catch_arch of catch is signal var_INC_FreQ : integer range 1 to 10; begin process (RST,PUSH,COMP) begin if RST = '0' then var_INC_FREQ <= 1; elsif rising_edge(PUSH) then if COMP = 8 then SCORE_COUNT <= '1'; var_INC_FREQ <= var_INC_FREQ + 1; end if; else SCORE_COUNT <= '0'; end if; end process; INC_FREQ <= var_INC_FREQ; end catch_arch; --- Quote End --- Thanks alot !
