Error (10644): Verilog HDL error at flexspi_dqs_phase_chain.v(81): this block requires a name
The qar seems corrupted.
I use Quartus prime 21.1 std (latest supporting the Cyclone 5).
See the attached picture for the error.
- YEan4 years ago
Contributor
Hi there,
Quartus Pro and Quartus standard use different front end code base. Unfortunately, we have no plan to change Quartus Standard front end currently.
Ean
- AEsqu4 years ago
Contributor
I will use Synplify for now then.
Please inform us when Quartus STD properly compiles the verilog.
Alex.
- RichardT_altera4 years ago
Hi @AEsqu
The Quartus standard use a different synthesis engine or parser so I doubt that this will be supported in future.
You may workaround this error by adding a line as below
for (j=0;j<DATA_LEARN_PHASE_NUM;j=j+1)
begin: a_name
Richard Tan
