14 years agoError 10500: VHDL Syntax
I am working on a code for a basic vending machine that will give out a product at 75cents BUt for some reason I dont know how to fix this syntax error
Library ieee;
Use ieee.numeric_std.all;...
9 years ago --- Quote Start --- Hi Daixiwen, My code was perfect, your site that ate the tabs after i did ctrl+c ctrl+v from Quartus (one more thing to solve). --- Quote End --- Sorry I didn't meant your code wasn't good, but as in any forum, you need to put some code tags in order to prevent the forum engine from trying to reformat the text. The code tags just say that we want to keep the spaces as they were written and don't want the web server to mess with them. --- Quote Start --- I tried to show you this error of Quartus because i believe that Altera(now Intel) can fix things like that and so get more adepts to use its tools. I never used this forum of Altera but i liked of one thing, you answers very fast! I confess that i did not have a real doubt, but a complain. Good companies receive well the criticisms, but i did not see that here. I hope that Altera could improve that and create a channel to complains and criticisms, and not just create but encourage the users to help Altera to build better tools. --- Quote End --- The problem is that this forum is not an official way to contact Altera about those matters. They hardly ever read it and you'll see mostly here other Altera users like us. If you want to make a suggestion to Altera, file up a service requested, as we have suggested. And yes our answers to your initial message may have been a bit negative, but calling a compiler "so bad" and "crap" twice because it uses the word "near" instead of "exactly there" in an error message isn't the best way to start a constructive discussion imho.
