14 years agoError 10500: VHDL Syntax
I am working on a code for a basic vending machine that will give out a product at 75cents BUt for some reason I dont know how to fix this syntax error
Library ieee;
Use ieee.numeric_std.all;...
14 years agoIf you don't want latches then either use clock edge so creating registers or keep it as it is but define what should happen if int_count is not max value. And any other areas.
The decision to drive the next state is up to the way you want it to be. If you use elsif as you have done then priority is given to first test and if not true then moves to next...
