Hi :) , plz any one can till me where is the error :( :( in this code" for circual Shifting Lift", the message error is "Error (10500): VHDL syntax error at modm.vhd(10) near text "begin"; expecting "end", or a declaration statement"
and the secone one
"Error (10500): VHDL syntax error at modm.vhd(33) near text "begin"; expecting "end", or a declaration statement"
library ieee;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_unsigned.all;
use IEEE.std_logic_arith.all;
package crll is
function crl(s1:std_logic_vector;index:integer) return std_logic_vector;
end crll;
package body crll is
begin
process
function crl(s1:std_logic_vector;index:integer) return std_logic_vector is
variable z : std_logic_vector(s1'high downto s1'low);
begin
if(index >= s1'length) then
assert false
report "crl: rotate index is greater than variable length can't rotate" severity error;
end if;
if(index < 0) then
assert false
report "crl: rotate index is negative,can't rotate" severity error;
end if;
if(index = 0) then
z:=s1;
else
for jj in 1 to s1'high loop
z:= s1(s1'high-jj downto 0) & s1(s1'high downto s1'high-jj+1);
if(jj = index) then
exit;
end if;
end loop;
end if;
return z;
end crl;
begin
crl;
end process;
end crll;
