9 years agoError 10500 Help me !!!
so this is one of my first VHDL codes...
(havent finished the cnt select part on the bottom^^) I get some "10500 vhdl Syntax error"s between 'begin' and 'with cnt select'... But why?? :(:confused: I can't find anything missing ._. library ieee; use ieee.std_logic_1164all; entity helloworld is port(key0: IN STD_LOGIC; Hex0: OUT STD_LOGIC_VECTOR(6 downto 0) ); end helloworld; architecture behaviour of helloworld is signal a: STD_LOGIC; signal cnt: STD_LOGIC := '0'; begin a <= not key0; if a = '1' then cnt <= cnt + 1; end if; if cnt = '16' then cnt <= '0'; end if; with cnt select . . . end behaviour;3 Replies
if statements must be in a procedural block of code - like a process
Also, it should be: use ieee.std_logic_1164.all;
@Tricky:
Oh thanks a lot , that must be the mistake^^ I didn't realize that as I'm more used to write in C. I'll try again now :) @sstrell: Thank you but this mistake is only here in the Thread from typing.
