11 years agoError 10349 in test bench
In my test bench I have the following architecture test of test_limiter is
signal high_limit_led :std_logic_vector(3 downto 0);
signal low_limit_led :std_logic_vector(3 ...
11 years ago --- Quote Start --- low_limit_led & limit_low_led? aren't you confusing yourself with such naming? I believe you meant: limit_low_led => low_limit_led; instead of low_limit_led => limit_low_led --- Quote End --- Oh opps thank you so much.
