14 years ago
Error (10327): VHDL error at test.vhd(24): can't determine definition of operator "="
Hello everybody,
I am new to vhdl and stuck on an error message :
Error (10327): VHDL error at test.vhd(24): can't determine definition of operator ""="" -- found 0 possible definitions
I used :
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
and declared:
port (Q : in signed(3 downto 0));
variable Q_1 : unsigned(0 downto 0);
... here is the line of code that have the error
if (q(0)="0" and q_1="1") then
Thank you for your time.
Regards.
    --- Quote Start ---
    well you better tell us what you want to do with Q and Q_1.
    you can just say:
    Q_1(0) := Q(0);
    --- Quote End ---
    sorry for not making it clear. what i wanted to do was to assign the 0th index of Q to Q_1.
    Q_1:= Q(0);
    thank you for your time :)
    I mean what actually you are trying to do in your module in general.
    Regarding your errors you need to assign same type on either side of =
    a single bit is of value (0 or 1)and can be assigned to any other single bits. So are multiple grouped bits. But a bus need to be same type e.g. std_logic_vector or signed or unsigned on either side of = or use cast like:
    data_signed <= signed(data_std_logic);
    Try using single quotes(') instead of double quotes (") around the values you're testing against. ' is for characters, " is for strings.
