13 years agoIf I understand right, you have removed the original code which the question title is referring to. Deleting the post completely would be similarly meaningful.
Apart from this strange practice, I also wonder you checked the code line by line, although Quartus shows you the line where the error occured? Now the code is still useless, because it's not generating any output.
