14 years ago
Error 10327: Can't determine definition of operator ""=""
hello everyone, i am newbie in quartus2, an d I am trying to write a 2 digit bcdcounter, but i facing some error
line 27 :Error 10327: Can't determine definition of operator ""=""
the following is the code
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
entity bcdcounter1 is
port(
RST : in std_logic;
Digit1_0 : out unsigned(3 downto 0);
Digit10_0 : out unsigned(3 downto 0);
SW1 : in std_logic;
clk : in std_logic
end bcdcounter1;
architecture bcdcounter1_arch of bcdcounter1 is
signal Digit1 : unsigned(3 downto 0);
signal Digit2 : unsigned(3 downto 0);
begin
--BCD up counter
process(clk, RST)
begin
if RST = '0' then
Digit1 <= (others => '0');
Digit2 <= (others => '0');
elsif rising_edge(clk) then
if (SW1 = '1') then
if (digit1 = '8') then
if Digit2 < 9 then
Digit2 <= Digit2 + 1;
else
end if;
else
end if;
else
if Digit1 < 9 then
Digit1 <= Digit1+1;
else
end if;
end if;
end if;
end process;
Digit1_0 <= Digit1;
Digit10_0 <= Digit2;
end bcdcounter1_arch;
    '8' is not a valid number. I think you meant 8 (without the ' )
    Also, std_logic_arith is not a standard library. you should use numeric_std instead.
    Right,
    use the numeric_std lib.
    library ieee;
    use ieee.std_logic_1164.all;
    use ieee.numeric_std.all;
    Than you can write:
    if (Digit1 = 8) then
    or
    if (digit1 = to_unsigned(8, digit1'length)) then
    thanks you, Tricky and Nicolas...^^
    I have solve my problem....thanks so much...
    --- Quote Start ---
    --- Quote End ---
    thanks you tricky, you are very great...i have solve my problem
