18 years agoError 10327: Can't determine definition of operator ""+""
Hello to everybody, could someone tell me what's wrong in the following code? library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity round16to12 is ...
8 years agoIn a combinational design you need to care that output signals are set in all branches of a conditional statement. If you review the decoder process, you'll realize that it's not the case for sign and ofv. The error message is clearly explaining the issue, by the way.
Simply add a default assignment as first process statement, e.g. sign <= '0'; ovf <= '0';
