18 years agoError 10327: Can't determine definition of operator ""+""
Hello to everybody, could someone tell me what's wrong in the following code? library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity round16to12 is ...
11 years agoAlmost definately not.
How do you expect a 50x50 image to arrive at the same time? why did you make some massive array of unsigned? why not just a 2d array of unsigned:
type image_array_t is array(0 to 49, 0 to 49) of unsigned(7 downto 0);
signal my_image : image_array_t;
for x in my_image'range(1) loop
for y in my_image'range(2) loop
my_image(x,y) <= something;
end loop
end loop;
But if you expect a 50x50 image to just magically appear, I suspect there is something more fundamentally wrong with your design than a '-' function not working. The error you had will be because you sliced something wrong somewhere (and because it is rather hideous to look at I cant be bothered to find it right now)
