18 years agoError 10327: Can't determine definition of operator ""+""
Hello to everybody, could someone tell me what's wrong in the following code? library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity round16to12 is ...
18 years agoDoes Quartus not optimise based on reachability analysis? If I code a counter that wraps around at 255, does it not infer an 8-bit counter? I know Max Plus II never did, but surely Quartus can do this...
Also, why do you say use signed/unsigned all the time? Most of the time, you only *need* vectors for the top level port pins. Just pass integers around your design hierarchy the rest of the time. Typing to_integer() isn't that much grief anyway is it? :-)? All IMHO of course! Cheers, Martin
