15 years agoError 10327: Can't determine definition of operator ""-""
Hi!
I'm getting this error all the time... and I don't know how to solve this because i'm still a rookie e this thing. Can anybody help me with that and tell me what i'm doing wrong? ------------------------------ Error 10327: Can't determine definition of operator ""-"" ------------------------------ Code: LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.all; USE IEEE.STD_LOGIC_ARITH.all; USE IEEE.STD_LOGIC_SIGNED.all; ENTITY Rec_dados IS PORT( RXD : IN STD_LOGIC; clock_115KHz : IN STD_LOGIC; data_ready : OUT STD_LOGIC; accx_out : OUT STD_LOGIC_VECTOR(15 DOWNTO 0); accy_out : OUT STD_LOGIC_VECTOR(15 DOWNTO 0); accz_out : OUT STD_LOGIC_VECTOR(15 DOWNTO 0)); END Rec_dados; ARCHITECTURE Behavior OF Rec_dados IS SIGNAL count : STD_LOGIC_VECTOR(6 DOWNTO 0); SIGNAL accx_out_int, accy_out_int, accz_out_int : STD_LOGIC_VECTOR(15 DOWNTO 0); BEGIN PROCESS BEGIN WAIT UNTIL clock_115KHz'EVENT and clock_115KHz = '1'; IF count < 32 THEN count <= count + 1; END IF; IF count > 31 AND count < 48 THEN accx_out_int(47 - count) <= RXD; count <= count + 1; END IF; IF count > 47 AND count < 64 THEN accy_out_int(63 - count) <= RXD; count <= count + 1; END IF; IF count > 63 AND count < 80 THEN accz_out_int(79 - count) <= RXD; count <= count + 1; END IF; IF count > 79 THEN accx_out <= accx_out_int; accy_out <= accy_out_int; accz_out <= accz_out_int; data_ready <= '1'; END IF; END PROCESS; END Behavior; Thanks everybody!
