Youn are driving here wrong:
w_ptr_succ <= std_logic_vector(unsigned(w_ptr_reg)+1); w_ptr_succ <= std_logic_vector(unsigned(r_ptr_reg)+1); Obviously you need to insert a switch to decide which option to drive. - Altera_Forum
Seems rather like a copy and past error. I guess this is intended:
r_ptr_succ <= std_logic_vector(unsigned(r_ptr_reg)+1); - Altera_Forum
thank you for help!!! I found the error...
w_ptr_succ <= std_logic_vector(unsigned(w_ptr_reg)+1); w_ptr_succ <= std_logic_vector(unsigned(r_ptr_reg)+1); really is: w_ptr_succ <= std_logic_vector(unsigned(w_ptr_reg)+1); r_ptr_succ <= std_logic_vector(unsigned(r_ptr_reg)+1); Now compile... Thank you so much!!
