10 years agoError (10028): Can't resolve multiple constant drivers for net <name> at <??>
All, Here is one of my Verilog trial-learning code: ============================================================== // Verilog learning example
module SRAM_Read_Write_Sync ( nrst, Writeclk, ...
10 years agoKeith -
There's a difference between code that is legal verilog and will compile without errors in a simulator, and code that will synthesize to hardware, which is usually the ultimate goal unless you're just trying to model behavior in simulation. Your second post has an always block that is sensitive to the rising edge of two different clocks. This doesn't make much sense even for modeling, and it would definitely not synthesize. This might work better:
module SRAM_Read_Write_Sync ( nrst, Writeclk, Readclk, EQ, write_addr, read_addr);
input nrst, Writeclk, Readclk;
output EQ;
output write_addr;
output read_addr;
// Declare the address counters as 9-bit counters
reg write_addr;
reg read_addr;
reg EQ;
// increment Write address or do a reset
always @ (posedge Writeclk or negedge nrst)
begin
if (!nrst)
write_addr <= 9'h0;
else // Unlike VHDL, you don't need to check for Writeclk high here.
write_addr <= write_addr + 1;
end
// increment Read address or do a reset
always @ (posedge Readclk or negedge nrst)
begin
if (!nrst)
read_addr <= 9'h0;
else // Unlike VHDL, you don't need to check for Readclk high here.
read_addr <= read_addr + 1;
end
// read_addr and write_addr are generated from different clocks so
// you probably don't want to compare them directly in one clock domain.
// Maybe just do a combinational compare (not clocked).
always @*
begin
if (read_addr == write_addr)
EQ = 1'b1;
else
EQ = 1'b0;
end
endmodule
