9 years agoerror : selected device has 126 RAM location(s) of type M9k.
I made the signal with NCO IP. We then testbench the signal. First, I added .sip and .qip files to the project and compiled the following code. But I got an error and I do not know why. https://ww...
9 years ago --- Quote Start --- BUT chip of my FPGA device is EP4CE40F23C7. what is the bigger than this. AND IS it Ok to change the device in quartus? --- Quote End --- If that is your chip, then the IP you have created will not fit into it, and you will either need to modify the IP or buy a new device.
