10 years agoEnable_unused_rx_clock_workaround
Can someone please tell me what this constraint does and when it is needed? Searching on the Altera site only pulls up this:
https://www.altera.com/support/support-resources/knowledge-base/solutions/fb325122.html Not a lot of information there. We're developing on the Arria 10 SoC dev kit and so far the .qsf files for all of the reference designs we have downloaded include some variation of the following: set_instance_assignment -name ENABLE_UNUSED_RX_CLOCK_WORKAROUND ON -to AE33 set_instance_assignment -name ENABLE_UNUSED_RX_CLOCK_WORKAROUND ON -to AD31 set_instance_assignment -name ENABLE_UNUSED_RX_CLOCK_WORKAROUND ON -to AD35 set_instance_assignment -name ENABLE_UNUSED_RX_CLOCK_WORKAROUND ON -to AC33 set_instance_assignment -name ENABLE_UNUSED_RX_CLOCK_WORKAROUND ON -to AB31 set_instance_assignment -name ENABLE_UNUSED_RX_CLOCK_WORKAROUND ON -to AB35 set_instance_assignment -name ENABLE_UNUSED_RX_CLOCK_WORKAROUND ON -to AA33 set_instance_assignment -name ENABLE_UNUSED_RX_CLOCK_WORKAROUND ON -to Y35 set_instance_assignment -name ENABLE_UNUSED_RX_CLOCK_WORKAROUND ON -to AG33 set_instance_assignment -name ENABLE_UNUSED_RX_CLOCK_WORKAROUND ON -to AH35 None of the reference designs includes the JESD204B core. The number of pins constrained seems to vary depending on how many transceivers are used in the reference design. Why is this constraint not documented anywhere, at least not that I can find? Thanks, BobNo RepliesBe the first to reply
