RichardWH
3 years agoEMIF Calibration Debug Toolkit "Firmware is not done running last command" error
We recently upgraded our Quartus Linux machine from Ubuntu version 18.04 to 20.04.
Now the EMIF Debug Toolkit returns the following errors when trying to re-calibrate. Used to work fine under Ubunt...
AdzimZM_Altera
3 years agoHi Richard,
Thank you for your update.
I will check with engineering team about the toolkit failure with firmware.
Just to confirm, you found the problem when using the EMIF IP example design right?
If yes, can you share the design file here?
Thank you.
Adzim
