Embedded_Command_Shell.bat from script flow
I am trying to develop a script flow for Quartus/HPS in Windows. One part I am stuck on is related to commands that only work if I am inside the "Embedded_Command_Shell.bat".
For example, if I want to run the command "sopc-create-header-files", I must be in the shell generated from "Embedded_Command_Shell.bat" and then manually type in the command. Obviously having to manually type things is not ideal for a scripted flow.
Is there a way to get the Embedded_Command_Shell.bat to launch and then run a command? Something like:
"Embedded_Command_Shell.bat -execute sopc-create-header-files
- hareesh
i am working on this. if don't mind can please share little bit more information about this
- RPett4
I want to know how to run "sopc-create-header-files" from a Windows Batch File.
- hareesh
bellow article will helps you. please try that batch file
- hareesh
